I am using ViacadPro 11 saving files of 125,000 KB and it can take 5 minute to write the file CPU usage for the program is around 15% and there is plenty of CPU available Any ideas as to what is the issue ? V11 is supposed to be multi threading
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
I am using ViaCadPro 12, with a desktop with a graphics card. Saves are quick. Before I got the compatible Graphics Card, saves and autosaves took a long time. Sam
ViaCad 10 Pro ViaCad 9 Windows 10
>>Any ideas as to what is the issue ? The File Write command is primarily driven by size of file and disk access/speed. Some benchmarks I once did showed getting a SSD provided me with the most improvement for read and writing of files. You might also try turning on compact files. Turning off compact files removes saving of the display list data to the file. >>V11 is supposed to be multi threading Some parts of PunchCAD are multi-threaded but saving native files is not. Tim
