TruggyDriver69
#1 Posted : Wednesday, April 12, 2023 4:44:09 PM(UTC)
TruggyDriver69
Is there a way to make an accurate countersink other than using the chamfer tool? Eg: a m3 FHS has a countersink of 90 degrees. ViaCad 14, build 1624, Mac OS Ventura 13.2. Thanks.
24c
#2 Posted : Thursday, April 13, 2023 1:40:11 AM(UTC)
24c
Was thanked: 73 time(s) in 53 post(s)
@TruggyDriver69
In SharkCAD you have this tool, not sure if it's in ViaCAD (it should be) and in the "status" bar you can edit the countersink properties
Screenshot 2023-04-13 at 08.37.43.png (305kb) downloaded 0 time(s).
Screenshot 2023-04-13 at 08.38.03.png (197kb) downloaded 0 time(s).
macOS Tahoe-v17 beta b1908
GARLIC on 4/13/2023(UTC)
TruggyDriver69
#3 Posted : Thursday, April 13, 2023 9:23:03 AM(UTC)
TruggyDriver69
Originally Posted by: 24c Go to Quoted Post
@TruggyDriver69
Yea I have that tool for viacad but it doesn’t work. It just removes a chunk of the part in a different area or I get an error message.
24c
#4 Posted : Friday, April 14, 2023 6:26:01 AM(UTC)
24c
@TruggyDriver69
If you've already made a hole, then the chamfer tool is your only option, unless you write over the existing hole.
I must admit I find the descriptive names quite confusing, but the first three boxes relate to your hole size and the next two relate to the counterbore or countersink details.The last one is the drill point angle eg 118º or whatever (if zero it is flat bottomed hole)
Most of the time I am doing a through hole... so here are a few screenshots showing how each box relates, the last one is a blind hole using a 118º pointed drill
I did see this documentation from ViaCAD 12 http://docs.imsidesign.com/projects/ViaCAD-V12/ViaCAD-V12/Welcome/Solid-Modeling/Feature-Based-Solid/
Hopefully you'll get the idea from the screenshots.
Mike
Edited by user Friday, April 14, 2023 6:45:10 AM(UTC)  | Reason: typo
Screenshot 2023-04-14 at 13.18.05.png (732kb) downloaded 7 time(s).
Screenshot 2023-04-14 at 13.18.39.png (555kb) downloaded 3 time(s).
Screenshot 2023-04-14 at 13.20.00.png (544kb) downloaded 2 time(s).
Screenshot 2023-04-14 at 13.21.26.png (562kb) downloaded 2 time(s).
Screenshot 2023-04-14 at 13.36.09.png (596kb) downloaded 5 time(s).
thanks 3 users thanked 24c for this useful post.
TruggyDriver69 on 4/14/2023(UTC), GARLIC on 4/14/2023(UTC), MPSchmied on 4/14/2023(UTC)
TruggyDriver69
#5 Posted : Friday, April 14, 2023 12:06:39 PM(UTC)
TruggyDriver69
I was able to figure out how to make the countersink holes. Thanks for the help everyone.
Edited by user Friday, April 14, 2023 12:57:04 PM(UTC)  | Reason: Not specified
CNC_Kid
#6 Posted : Tuesday, April 18, 2023 8:43:19 PM(UTC)
CNC_Kid
What was the fix?
VCpro v11-1417
Win10Pro 32GB
Xeon E3-1270-v3 3.5GHz
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
creativecad
#7 Posted : Tuesday, April 18, 2023 9:21:19 PM(UTC)
creativecad
I believe you place the outside diameter of the countersink where it says countersink, and the inside diameter where it says diameter. Also, there is a spot to place the angle of the countersink hole, and a few more options. It is a tad bit confusing. Other than that it is like the simple hole tool...pick a face and place the hole.
ViaCad 10 Pro
ViaCad 9
Windows 10
TruggyDriver69
#8 Posted : Wednesday, April 19, 2023 6:08:06 AM(UTC)
TruggyDriver69
What was the fix?
User error lol.
