access to beta forum :-)
Can I get access to the v14 beta please? Thanks!
Hi Can I also get access to the Beta forum Thank you
Can I please have access to the Beta forum? Thanks!
Hello. I'm stuck in the Ventura nightmare. Is it possible to get access to the ViaCAD Pro v14 Beta? Thanks, Nick.
I've found it. Sorry to waste your time.
Request access please. Thanks!
Hi Tim, Old user since Concept Unlimited, then Shark V5, V9, V10. I bought a new MacBook Pro 14 with Ventura and would like to test the V14 version. Can I also get access to the Beta forum Thank you GB
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Hi, can I please have access to the v14 beta forum please :)
Is there now a windows version of viacad 14? If so, can I please have access to beta forum? Thank you
Is the beta avail for PC now? Considering the jump from 10 to 14. thanks. Would like to try it if I could!
Thanks: 7 times Was thanked: 5 time(s) in 2 post(s)
Hello. Is it possible to give me the access to beta forum? Thank you!
Thanks: 264 times Was thanked: 131 time(s) in 101 post(s)
Hallo, i would like to participate in the beta program. Thank you.
Hello Tim, Can you please provide access to the beta versions for me? I am now running 14.4.0 Build 1616. I am having issues with the file name changes, when I use Model toSheet templates. Thanks Skiddy
