ViaCad opens then hides.
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Having a problem that just started abruptly out of nowhere and has been going on for about a week. When I open ViaCad it opens but then real quickly it closes down to the dock on my desktop. I can open it from there normally and the only problem after that is I have to adjust the window to have access to the window buttons. It only happens on the initial startup of the program. Running Mac OS Ventura 13.2. ViaCad v14.0.0 Build 1616. Anyone else having this issue?
Would it be possible for you to download and Build 1622 and then send me the log file? I've added more information to try and track down some launching issues on macOS Ventura. The file that I need sent to me after you see a failed launch is: /Users/Shared/punchcad.log Thanks Tim
Originally Posted by: Tim Olson Would it be possible for you to download and Build 1622 and then send me the log file? I've added more information to try and track down some launching issues on macOS Ventura. The file that I need sent to me after you see a failed launch is: /Users/Shared/punchcad.log Thanks Tim
How do I go about what you suggest? It shows that I am running the most current build (no update necessary). Thanks.
Edited by user Thursday, March 23, 2023 5:02:19 AM(UTC)
(1,512kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
>>How do I go about what you suggest? It shows that I am running the most current build (no update necessary). I provided you access to the beta forum where we have links to a 1622 WIP build. Once the WIP looks good, we will move it over to the in app updater. Tim
Originally Posted by: Tim Olson >>How do I go about what you suggest? It shows that I am running the most current build (no update necessary). I provided you access to the beta forum where we have links to a 1622 WIP build. Once the WIP looks good, we will move it over to the in app updater. Tim
I downloaded as you suggested but the file can't be opened. I noticed on the download link it says windows. Edit: I was able to download 1622 but no improvement. Thanks.
Edited by user Thursday, March 23, 2023 10:46:00 AM(UTC)
| Reason: Post updated.
Maybe you download the Windows links Zunair posted. Check this thread in the beta forum.
https://forum.punchcad.c...ts&t=10665#post40628 Tim Olson IMSI Design/Encore
Originally Posted by: Tim Olson lol. Yea I figured it out and found it. Se my last post.
Can you post or send me the punchcad.log file? /users/shared/punchcad.log Tim
Originally Posted by: Tim Olson Can you post or send me the punchcad.log file? /users/shared/punchcad.log Tim
How do I find it??
The punchcad.log file is located in the below folder /Users/Shared Tim
Originally Posted by: Tim Olson The punchcad.log file is located in the below folder /Users/Shared Tim
Ah, ok. I think I found it. Was trying spotlight search but that wasn’t working. Found it using the go menu.
It won’t let me upload it to the forum. I get this error message.
Edited by user Friday, March 24, 2023 5:54:46 AM(UTC)
Not sure if this will post.
The forum won’t let me upload anything. It just glitches out.
Originally Posted by: TruggyDriver69 The forum won’t let me upload anything. It just glitches out.
Can you email to me at Tim.olson @ encore .com
Originally Posted by: Tim Olson Originally Posted by: TruggyDriver69 The forum won’t let me upload anything. It just glitches out.
Sent. Let me know if you get it. Thanks.
