la mouche
#1 Posted : Wednesday, June 17, 2009 7:04:12 AM(UTC)
la mouche
Hello,
model to sheet.
bug display model plane, if we remove the history ...:confused:
http://rapidshare.com/files/245.../2009-06-17_1453.swf.zip
Thank you
Best regards.
Antoine
montree.sfx.zip (140kb) downloaded 5 time(s).
#2 Posted : Monday, June 22, 2009 11:34:47 AM(UTC)
Hi Antoine,
I was not able to repeat. Could you also post the file after the model to sheet?
la mouche
#3 Posted : Tuesday, June 23, 2009 2:01:50 AM(UTC)
la mouche
Hello Tim,
The file.
Thanks.
Antoine
montre-2.sfx.zip (139kb) downloaded 5 time(s).
#4 Posted : Tuesday, June 23, 2009 9:21:09 AM(UTC)
Hello Antoine
When I open the Draw View Properties dialog box for your views, I noticed that you have a pen style "Pointille fin" set for Hidden, Holes, and Tangent. I'm not sure if this is intentional, but this would explain why you have all the dotted lines in your draw views. Set these to "Ignore" to remove these lines.
Holler back if this does not solve your display issue or if I have misunderstood.
#5 Posted : Tuesday, June 23, 2009 8:40:41 PM(UTC)
Hi Tim
When you remove links of the 3 pieces on the ensemble layer your left with 3 acis solids (base back and lens) but the model to sheet is not the same as before you remove all links.
The base of the watch geometry has changed in model to sheet like the remove link command has rolled the solid back before the surface trim was added?. The solid displays correctly after removing links but it looks like the model to sheet is pulling from a different version of the solid.
montreeafterremovelinks.slt (238kb) downloaded 5 time(s).
la mouche
#6 Posted : Wednesday, June 24, 2009 1:29:40 AM(UTC)
la mouche
hello Tim,
yes,
I use my style "dotted " for the hidden lines and edges tangent because SharkFX dont' manage the effect of overlapping.
Indeed, the boundary lines are sometimes exactly on the same line as the hidden edges.
Tim?
My question was:
The circle you see in the left view is a ... "parasite" of the parent surface which was used to cut my case body.
it is a bug
Thank you in advance.
Image 1.jpg (14kb) downloaded 5 time(s).
#7 Posted : Wednesday, June 24, 2009 8:32:57 AM(UTC)
Tim, Antoine .. I often get this problem .. an arc within an object undoes itself into a circle - something needs fixing here !
