SharkCad 12 Pro Windows Quit Working
Thanks: 190 times Was thanked: 163 time(s) in 112 post(s)
Shark just would not open, downloaded the latest version, which was also
difficult because of security issues.
Will not load, as per the included error, you can click "Ignore" a
hundred times for different files, nothing works.
(169kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Larry, It looks like a write error. Do you have permissions for E drive? Tim
Thanks Tim,
I've been using Shark on E:/ for years, yesterday indicated shortcut can no longer find Shark.
Maybe I should try installing on C;/
Larry,
Update: Installed fine on C:/, strange all other programs on E:/ work fine.
I might have to do the unthinkable for Shark, Switch over to the Mac.
Edited by user Wednesday, March 1, 2023 3:46:46 PM(UTC)
Thanks: 342 times Was thanked: 229 time(s) in 156 post(s)
Originally Posted by: L. Banasky Switch over to the Mac
No. Please do this not. then you need for every new Mac-Version a new Shark-Version.
In Windows also you can use all older Versions and 32 bit Software.
2 users thanked MPSchmied for this useful post.
Thanks MP, Must have been a nightmare that I had switching to a Mac. Thanks, Larry
