Import .vc3 file into Pro v14
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
I recently upgraded to Viacad Pro v14 and have a number of files from older versions that are .vc3 not .vcp. I thought that everything would be backwards compatible for importing. I don't necessarily need all of the files because they are older but I expected a new program would read old files. Thanks Kevin
Thanks: 231 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: ultrahawkeye I recently upgraded to Viacad Pro v14 and have a number of files from older versions that are .vc3 not .vcp. I thought that everything would be backwards compatible for importing. I don't necessarily need all of the files because they are older but I expected a new program would read old files. Thanks Kevin
Did you try import ?
On my side I just checked : with V14, I can still open
.cu files made in
2004 ...
ViaCAD Pro 14 reads files dating back to CADD Pro for all products. The same file format is used for all ViaCAD, SharkCAD, and TurboCAD Mac products. I would need to see the file to find out what is wrong. If you open any of these files in a text editor, the first line should be... CADD-PRO14.00 CSI-COM Tim
Originally Posted by: Tim Olson ViaCAD Pro 14 reads files dating back to CADD Pro for all products. If you open any of these files in a text editor, the first line should be... CADD-PRO14.00���CSI-COM��� Tim
This is the first line - "bplist00”\NSURLNameKey_NSURLFileSizeKey_NSURLFileResourceTypeKey_32 Clary Drive.vc3 ,|G_NSURLFileResourceTypeRegular/J_d "
32 Clary Drive.vc3
(1kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: ultrahawkeye This is the first line - "bplist00”\NSURLNameKey_NSURLFileSizeKey_NSURLFileResourceTypeKey_32 Clary Drive.vc3�,|G_NSURLFileResourceTypeRegular/J_d����������������������������"
This file has no data it is 170 bytes and appears to be a reference or pointer to the actual file. Did you copy/backup or try restoring this file from a backup or damaged file? Is this the only copy of the file you have?
Edited by user Sunday, March 12, 2023 2:15:28 PM(UTC)
Originally Posted by: jdi000 Originally Posted by: ultrahawkeye Is this the only copy of the file you have?
No, unfortunately it's the only copy. Thanks for the help.
