ultrahawkeye
#1 Posted : Monday, February 20, 2023 10:00:20 AM(UTC)
ultrahawkeye
I recently upgraded to Viacad Pro v14 and have a number of files from older versions that are .vc3 not .vcp. I thought that everything would be backwards compatible for importing. I don't necessarily need all of the files because they are older but I expected a new program would read old files.
Kevin
#2 Posted : Monday, February 20, 2023 11:12:34 AM(UTC)
Kevin
Did you try import ?
On my side I just checked : with V14, I can still open .cu files made in 2004...
#3 Posted : Monday, February 20, 2023 4:13:39 PM(UTC)
ViaCAD Pro 14 reads files dating back to CADD Pro for all products.
The same file format is used for all ViaCAD, SharkCAD, and TurboCAD Mac products.
I would need to see the file to find out what is wrong.
If you open any of these files in a text editor, the first line should be...
CADD-PRO14.00CSI-COM
MPSchmied on 2/21/2023(UTC)
ultrahawkeye
#4 Posted : Sunday, March 12, 2023 5:45:35 AM(UTC)
ultrahawkeye
CADD-PRO14.00���CSI-COM���
This is the first line - "bplist00”\NSURLNameKey_NSURLFileSizeKey_NSURLFileResourceTypeKey_32 Clary Drive.vc3,|G_NSURLFileResourceTypeRegular/J_d"
32 Clary Drive.vc3 (1kb) downloaded 3 time(s).
#5 Posted : Sunday, March 12, 2023 7:21:11 AM(UTC)
This is the first line - "bplist00”\NSURLNameKey_NSURLFileSizeKey_NSURLFileResourceTypeKey_32 Clary Drive.vc3�,|G_NSURLFileResourceTypeRegular/J_d����������������������������"
This file has no data it is 170 bytes and appears to be a reference or pointer to the actual file. Did you copy/backup or try restoring this file from a backup or damaged file? Is this the only copy of the file you have?
Edited by user Sunday, March 12, 2023 2:15:28 PM(UTC)  | Reason: Not specified
ultrahawkeye on 3/16/2023(UTC)
ultrahawkeye
#6 Posted : Thursday, March 16, 2023 3:59:46 AM(UTC)
ultrahawkeye
No, unfortunately it's the only copy. Thanks for the help.
