Steel profiles & weld symbols
Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I'm currently using VC Pro. Is there a steel profile library available? I also need to be able to insert weld symbols, is there a option for this with VC?
No. I created my own steel profile library. Some profiles i made by myself and other are imported from a parametric draftboard library which was made by Posh.de very long time ago. The content library in the concept explorer is to slow. I don't use it.
