Dyn_Metalworks
#1 Posted : Monday, January 23, 2023 4:45:24 PM(UTC)
Dyn_Metalworks
I'm currently using VC Pro. Is there a steel profile library available? I also need to be able to insert weld symbols, is there a option for this with VC?
#2 Posted : Monday, January 23, 2023 8:40:40 PM(UTC)
No. I created my own steel profile library. Some profiles i made by myself and other are imported from a parametric draftboard library which was made by Posh.de very long time ago.
The content library in the concept explorer is to slow. I don't use it.
