#1 Posted : Monday, January 23, 2023 11:36:07 AM(UTC)
I need the Unfold Tool. When will the Windows Version of v. 14 be released?
https://youtu.be/fxumxd7...HCoiHCLuDxxdtzqwQl00QM16
specktech on 1/25/2023(UTC)
#2 Posted : Monday, January 23, 2023 1:01:49 PM(UTC)
No we released Mac first because of the need to get a macOS Ventura solution out.
We getting closer on Windows beta...
thanks 2 users thanked Tim Olson for this useful post.
MPSchmied on 1/23/2023(UTC), specktech on 1/25/2023(UTC)
Jean-Francois Jacques
#3 Posted : Monday, January 23, 2023 2:34:02 PM(UTC)
Canada
Unfold tool doesn't work correctly for me.... Mac SharkCad build 1616
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
thanks 1 user thanked Jean-Francois Jacques for this useful post.
#4 Posted : Monday, January 23, 2023 2:39:06 PM(UTC)
Can you attach or email me the file that does not unfold?
CNC_Kid
#5 Posted : Monday, January 23, 2023 3:24:20 PM(UTC)
CNC_Kid
Finding bugs that fast? Yikes.
I want a solid bug-free v14 for Win10/11.
I am actually willing to upgrade from VC-Pro to SC-Pro, but not willing to buy bugs.
VCpro v11-1417
Win10Pro 32GB
Xeon E3-1270-v3 3.5GHz
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
thanks 1 user thanked CNC_Kid for this useful post.
specktech
#6 Posted : Wednesday, January 25, 2023 1:44:14 PM(UTC)
specktech
Quick message for "MPSchmied" Your tip to work without the grid has been so awesome. Thankyou so much for that simple tip. I still use the grid quite a bit. But working in open space seems to really work well in ViaCAD. When you mentioned that the software is geometrically 100% accurate. I now see this. The snaps and construction lines are exactly where I want them. Also aligning items is working much better modeling in outer space. Thanks MPS. P.S. I guess you could print your items on paper then unfold them. Origami metal work. That unfold tool does look nice.
#7 Posted : Wednesday, January 25, 2023 3:32:20 PM(UTC)
Canada
Tim, what is the rule for the Unfold Tool ?? Surface without thickness (surface only) ?
Included 3 files
1- ACIS Error with the LampShade-3.sfx (solid part) (Sheet metal has always thickness !!)
2- LampShade.sfx ...looks fair (same area) but the hole are not in the good place.
3- LampShade-2.sfx very good
...the operations took around 6 minutes
LampShade.sfx (47kb) downloaded 3 time(s).
LampShade-2.sfx (40kb) downloaded 3 time(s).
LampShade-3.sfx (39kb) downloaded 4 time(s).
Screenshot 2023-01-25 at 16.19.43.png (831kb) downloaded 2 time(s).
specktech on 1/31/2023(UTC)
#8 Posted : Wednesday, January 25, 2023 4:03:25 PM(UTC)
Confirmed issue. Your example is a periodic surface (starts and end with same continuity).
Checking into...
creativecad
#9 Posted : Thursday, January 26, 2023 4:27:57 PM(UTC)
creativecad
https://www.punchcad.com/punch-viacad-pro
Thought you might want to know that the webpage for viacad v14 gives windows (and Mac) system requirements. I understand that v14 is Mac only at this time.?
ViaCad 10 Pro
ViaCad 9
Windows 10
thanks 1 user thanked creativecad for this useful post.
CNC_Kid
#10 Posted : Friday, January 27, 2023 8:08:30 PM(UTC)
CNC_Kid
It's a common requirements blurb that shows up across v12 too. They didn't mask out Win there.
The Mac specs also seem off. The application supports running on v10.11 "El Capitan" 32 & 64bit from 2015? Does it support Ventura on ARM?
I suspect some cart-before-horse going on.
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
#11 Posted : Friday, January 27, 2023 8:32:18 PM(UTC)
Why should it support ARM? If so, then Tim Olson should make also a Android-App. Please read what Tim Olson say about the Windows-Version - it is not matter what at time released on the website for the windows version.
#12 Posted : Saturday, January 28, 2023 1:59:50 AM(UTC)
Yes, all my development is on an ARM Mac.
However, v14 is creating Intel binaries that are using Rosetta on ARM computers. Universal binaries that are native to Intel & ARM will come later this year.
thanks 3 users thanked Tim Olson for this useful post.
MPSchmied on 1/28/2023(UTC), cgWerks on 1/30/2023(UTC), specktech on 1/31/2023(UTC)
cgWerks
#13 Posted : Monday, January 30, 2023 10:43:32 AM(UTC)
cgWerks
Canada
Hi Tim, and ***long time***!!! Great to hear from you, and thanks for this update. I’m hoping to go Apple Silicon in the next year or two, so this is good news. Have you heard any word on Spatial and native ARM for the modeling kernel (that you can share)?
Thanks, and all the best!
-Steve
Steve Wilkinson
thanks 2 users thanked cgWerks for this useful post.
jlm on 1/30/2023(UTC), specktech on 1/31/2023(UTC)
#14 Posted : Monday, January 30, 2023 11:30:04 AM(UTC)
Hey Steve good to hear from you!
Spatial provided us with a build but it was too late to integrate into v14 SP0 as we had an urgent need to get a release out for macOS Ventura.
I am planning on a v14 service pack for a universal build (intel/arm). I have a subcontractor working on some of the remaining third party libs.
specktech on 1/31/2023(UTC), cgWerks on 2/1/2023(UTC)
cgWerks
#15 Posted : Wednesday, February 1, 2023 5:27:42 PM(UTC)
cgWerks
Canada
That is good to hear. Last time I tried to look into which products/kernels were working towards Apple Silicon support, I couldn’t find anything about Spatial/ACIS having it in the works. If it’s almost ready to go into a product, I’m super happy to hear that!
-Steve
Guest (10)
