Hello,
can you please explain this message?
Normally, the shell should be possible
see the attach file please.
Antoine
(72kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
>>can you please explain this message? It is unable to shell the body because it cannot create the offset of the faces. Looking at the image, possibly because of self intersections of the offsetted face. It might work at a smaller thickness value. Tim
Originally Posted by: la mouche Hello, can you please explain this message? Normally, the shell should be possible see the attach file please. Thanks Antoine
Hi Antoine,
If possible, post your model and I will see if it is possible with a parasolid engine as well as in spaceclaim ?
hello Paul,
Thanks.
Here the file. arf not possible upload... 2,9 MB
Tim?
look my history, i think, my model is good.
Antoine
(52kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
hello,
another file
Tanks for your test and reply.
Antoine
shell2.sfx
(424kb) downloaded 5 time(s). la mouche attached the following image(s):
(180kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: la mouche hello, another file Tanks for your test and reply. Antoine
Hi Antoine,
The model as many errors. Use the "verify- Check object"
- Steve
Originally Posted by: la mouche another file Antoine
Hi Antoine,
I rebuilt the solid in VC pro. It will now shell OK.
- Steve
shell.vcp
(198kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
hello, Stevve Thanks for your reply. But.. your model is make with surfaces. looong work.
Originally Posted by: la mouche But.. your model is make with surfaces. looong work.
Hi Antoine,
Yes, it took about 30 minutes for what should of been under 5. The problems with the sweeps/guides really needs to be fixed.
I made the model the way I did to show that the shelling can be done if the model is correct, it is just that if the model is created by guide skin surfaces/solids then the model (in quite a lot of instances in the type of closed shape you want) will not be shelled due to bad curvature created by VC/Shark.
- Steve
Hi Antoine,
Read your shell2.sfx file into any of the 838 builds and do a Force Resolve Links. Your shell should work then.
http://www.csi-concepts.com/Demo/videos/noShell2.mov Regards
hello Tim, Thanks very much! Antoine
