#1 Posted : Monday, November 28, 2022 9:01:11 PM(UTC)
I actually had this problem around 2 or 3 months ago. I wish I wrote down how I previously resolved it. The problem is in a SharkCAD Pro v12 file, and even when I export to v12, even after compacting wnd resolving links beforehand, the problem travels.
The problem:
I invoke/call up the straight line, spline, circle, whatever, and only the helper or guidelines jitter into view. The desired geometry doesn't reveal itself until I finish or escape the operation.
But, in a brand new file, in the same instance of Shark, the draw tools for lines, splines, circles, etc behaves as normal.
See attached video.
Steps to try to figure it out:
I've gone through the menu of anything that looks like it can affect the curves being drawn. I've looked at the Gripper and Snaps, and still, I am failing.
I resolved it before, so I am perplexed as to how I figured it out in minutes wheras tonight I burned over a half hour trying.
Thanks for any input.
