relaxibus
#1 Posted : Monday, November 14, 2022 8:15:08 AM(UTC)
relaxibus
Was thanked: 73 time(s) in 42 post(s)
I would like to collect all open bugs (not new features) still present in SharkCAD Pro v12. I'm working on an Apple Mac mini M1, 8GB
Part of the points are collected from the "Suggestions for V14" in this forum: https://forum.punchcad.c...ts&t=10580#post40181
1) Mesh to Analytic doesn't work.
2) When objects are grouped, moving it becomes very slow to unpractical. Un-group, select all the same objects however works smoothly
3) Model to Sheet issues: https://forum.punchcad.c...t=9854&p=2#post39496
4) Assembling is impossible without removing Links for every move
5) Export metric STEP and not only "imperial"
6) CATIA & Co Import/export. Not only for Windows. If this is a license issue between Dassault and Punch, then you shall lower the Mac price as this features are a key point to go or stay for Shark
7) Improve reliability of links between objects and history tree (broken links, undo disasters, operation freeze with spinning wheel)
8) Undo sometimes creates disasters and you loose all your job done.
9) Apple Silicon Native with Metal support. We have a racecar but can't go fast.
It would be very appreciated first to fix all this issues prior to come with new features. Fusion is just a step away.
thanks 3 users thanked relaxibus for this useful post.
GARLIC on 11/14/2022(UTC), MPSchmied on 11/14/2022(UTC), jlm on 11/14/2022(UTC)
rockyroad_us
#2 Posted : Monday, November 14, 2022 9:16:01 AM(UTC)
rockyroad_us
I concur with item 1. It will be helpful if another video was posted using a different model other than the bunny using this method of mesh to analytic. I sometime find myself segmenting the mesh.
