creativecad
#1 Posted : Friday, October 7, 2022 2:14:01 PM(UTC)
creativecad
I am thinking this has got to be a bug in the program. When I tried doing 3d views with the MTS to show a phong or gouraud view, my viewports don't show it correctly. I am sure someone here has encountered this.
I show the polyline view, and the phong view of the same exact sheet that I print in the pictures.
Sam
Edited by user Friday, October 7, 2022 2:20:53 PM(UTC)  | Reason: Not specified
creativecad attached the following image(s):
ViaCAD Pro _Staircase phong view.jpg (134kb) downloaded 4 time(s).
ViaCAD Pro _Staircase polyline view.jpg (161kb) downloaded 2 time(s).
ViaCad 10 Pro
ViaCad 9
Windows 10
#2 Posted : Friday, October 7, 2022 2:49:03 PM(UTC)
I have sometimes also such half drawings with phong or gouraud, but this errors will be not printed and will be fixed after zoom using. This problem i watched only on bigger projects with many parts.
posh.de
#3 Posted : Monday, October 10, 2022 11:05:58 AM(UTC)
posh.de
for OpenGL problems under Windows do a driver update of the used graphics card ("Win+R > dxdiag") first. If using a lame integrated solution (e.g. intel (U)HD series), you might want switch to a dedicated nVidia GeForce GTX/RTX graphics card too, at least if a desktop system.
no way under macOS, drivers and hardware from Apple only.
#4 Posted : Monday, October 10, 2022 1:43:23 PM(UTC)
It's not graphics. I reported this ages ago. The shading seems to be converted to an image. You see this when you load it in certain pdf software. When the image is removed you can see what's underneath it. The image blocks off what's next to it. Make sure view boarders do not overlap and you may get away with it
MPSchmied on 10/11/2022(UTC)
Guest (6)
