motorsportjpn
#1 Posted : Monday, April 4, 2022 6:40:08 PM(UTC)
motorsportjpn
when I type a simple text "speed lab" it looks fine, when I rotate the text the inside lines in "peed ab" are not cut out correctly. It makes and 3d printing or machining work unless. the inside of the letters should have uniformed cutouts but they are all warped.
I have saved an image to show what's happening but I can't upload images here?
#2 Posted : Tuesday, April 5, 2022 3:01:00 AM(UTC)
Capture d’écran 2022-04-05 à 11.03.30.png (41kb) downloaded 4 time(s).
