SharkCAD 12 SFX 1591 text boundary line fail on MAC
when I type a simple text "speed lab" it looks fine, when I rotate the text the inside lines in "peed ab" are not cut out correctly. It makes and 3d printing or machining work unless. the inside of the letters should have uniformed cutouts but they are all warped. I have saved an image to show what's happening but I can't upload images here?
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: motorsportjpn when I type a simple text "speed lab" it looks fine, when I rotate the text the inside lines in "peed ab" are not cut out correctly. It makes and 3d printing or machining work unless. the inside of the letters should have uniformed cutouts but they are all warped. I have saved an image to show what's happening but I can't upload images here?
(41kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
