Dyn_Metalworks
#1 Posted : Tuesday, November 23, 2021 9:42:53 AM(UTC)
Dyn_Metalworks
When I convert this text to lines, I end up with jagged lines. How do I smooth this before cutting on the cnc?
Dyn_Metalworks attached the following image(s):
#2 Posted : Tuesday, November 23, 2021 9:59:33 AM(UTC)
Hello
Try using the Arcs from curve tool in the arc toolbar
So all the entities become arcs for smooth cnc cutting.
Edited by user Tuesday, November 23, 2021 10:02:02 AM(UTC)  | Reason: Not specified
thanks 2 users thanked jdi000 for this useful post.
L. Banasky on 11/23/2021(UTC), GARLIC on 11/24/2021(UTC)
#3 Posted : Wednesday, November 24, 2021 12:11:42 PM(UTC)
Was thanked: 237 time(s) in 159 post(s)
You made this wrong.
You need for good results:
http://www.cadkas.com/downgercad4.php
http://www.cadkas.com/dxf-splines-in-arcs.php
A very old Corel Draw Version i used 1999 made also good splines from Text.... But in SharkViaCAD i cant find such a Tool.
What when he have no curve already?
Edited by user Wednesday, November 24, 2021 12:12:58 PM(UTC)  | Reason: Not specified
Dyn_Metalworks
#4 Posted : Thursday, November 25, 2021 7:16:42 AM(UTC)
Dyn_Metalworks
Hello
I was able to find the Simplify Curves tool which didn't work, but not the Arcs from curves. Could you tell me where it's located? Thanks
#5 Posted : Saturday, November 27, 2021 8:53:27 PM(UTC)
Its in the Arcs-Section of the Toolbar.
GARLIC on 11/28/2021(UTC), damhave on 11/29/2021(UTC)
Dyn_Metalworks
#6 Posted : Monday, November 29, 2021 8:28:09 AM(UTC)
Dyn_Metalworks
Thank you for the reply, I'm using ViaCAD so it appears I don't have that tool.
murray
#7 Posted : Monday, November 29, 2021 10:03:24 PM(UTC)
murray
Do you set the text resolution to super fine before you convert to lines?
Dyn_Metalworks
#8 Posted : Tuesday, November 30, 2021 5:26:17 PM(UTC)
Dyn_Metalworks
Yes, I confirmed it was set to super fine.
#9 Posted : Wednesday, December 1, 2021 1:55:32 AM(UTC)
Did you use the right mouse button on the Text for context-menu Resolution. The Text resolution will be always down, also when your global setup is "super fine". Convertet you the Text to curves or Lines? Use just the CAD-Kas Software is my suggestion.
murray
#10 Posted : Wednesday, December 1, 2021 5:46:47 AM(UTC)
murray
Speculating, don't know if this'll make a difference, but is there a difference if you scale the text up with the resolution set super fine, convert to lines, then scale back down again?
MPSchmied on 12/1/2021(UTC)
Dyn_Metalworks
#11 Posted : Wednesday, December 1, 2021 6:20:08 AM(UTC)
Dyn_Metalworks
I ended up using inkscape for the text then importing the dxf into VC to finish the part. I appreciate everyone's replies.
