                I am using V11  trying to do a row of holes and grid of holes  Do use the linear array? I can not get it to work, need some guidance
Thanks: 315 times Was thanked: 190 time(s) in 135 post(s)
                Draw a hole, select it and use the linear Duplicate Tool, fill out the right values or take it from the darawing and press ok. and you have your holegrid in 2D. Make the right frame around the grid and you can extrude this as a perforated plate. A alternative to this is the pattern function of Shark Pro.
Edited by user  Monday, September 20, 2021 3:00:46 PM(UTC)
 | Reason: Not specified
    OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB |  Graphic: AMD Radeon RX Vega 56 | SharkCAD 15 Pro | Unit: mm
                How do I find and fix gaps in viaCAD v10?
                Why can't I extrude a draft angle from midpoint planes..
                Originally Posted by: dep2352  How do I find and fix gaps in viaCAD v10?
Gaps in profiles?
                Originally Posted by: dep2352  Why can't I extrude a draft angle from midpoint planes..
It's a confused scenario, extrude with draft from one side only and use linked mirror to provide the other.
             2 users thanked murray for this useful post.
