I am using V11 trying to do a row of holes and grid of holes Do use the linear array? I can not get it to work, need some guidance
Thanks: 355 times Was thanked: 261 time(s) in 171 post(s)
Draw a hole, select it and use the linear Duplicate Tool, fill out the right values or take it from the darawing and press ok. and you have your holegrid in 2D. Make the right frame around the grid and you can extrude this as a perforated plate. A alternative to this is the pattern function of Shark Pro.
Edited by user Monday, September 20, 2021 3:00:46 PM(UTC)
How do I find and fix gaps in viaCAD v10?
Why can't I extrude a draft angle from midpoint planes..
Originally Posted by: dep2352 How do I find and fix gaps in viaCAD v10?
Gaps in profiles?
Originally Posted by: dep2352 Why can't I extrude a draft angle from midpoint planes..
It's a confused scenario, extrude with draft from one side only and use linked mirror to provide the other.
2 users thanked murray for this useful post.
