The In-Stream Zoom Commands works not with the Multiselecting in the Solid-Tools together
Thanks: 361 times Was thanked: 268 time(s) in 175 post(s)
When using the In Stream Zoom Commands while Multiselect (Selecting multiple Lines with Shift and Mouseclick) in a Solid Tool, the Multiselecting breaks. The Normal Multiselecting with the Selection Tool works just with the trick that the Shift have to be released after using the In Stream Zoom Command. In Draftboard works the Multiselect correct together with the In-Stream Zoom, The Shift-Key don't have to be released there after the In Stream Zoom Command. Just the Ctrl have to be released and the Multiselecting can be finished.
Edited by user Friday, November 5, 2021 12:06:09 PM(UTC)
I was able to repeat this as well and will go over it with the developers. TY for bringing this to our attention.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
1 user thanked Todd Quinlan for this useful post.
The Multiselecting which i mean is with Shift and Mouseclick and not with the dragged Frame. If you use the In-Stream Zoom Commands and this kind of Multiselecting together with a Solid Tool will the operation be finished everytime in all versions greater than 1162. In-Stream Commands should never finishing any operation.
Maybe there are other ways for selecting a profile, but sometimes i used this way, and this zoom commands are very important for me, for example i have no idea how to place dimensions without this function.
See also:
http://forums.punchcad.c...sts&t=9563#post36327 OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB | Graphic: AMD Radeon RX 7900 XT | SharkFX9 Build 1162 | Unit: mm
I have to say, that this Bug is not very important, because it works with groups or select mask and is only needed for
extrusion and tube tool and extrusion works the most time with Push and Pull. Maybe this waste only time......
Edit: The Same Problem is for example with the Cover Surface Tool. It should work, thats all. Otherwise i have always to make groups or layers first. Also the Multiselecting with Shift and Mouseclick should work with the Select Tool when using In-Stream Zoom Commands and releasing just the Ctrl-Button for keeping Multiselecting.
Edited by user Monday, November 8, 2021 4:14:08 AM(UTC)
