tombstone
#1 Posted : Monday, September 20, 2021 11:08:34 AM(UTC)
tombstone
I am using V11 trying to do a row of holes and grid of holes Do use the linear array?
I can not get it to work, need some guidance
#2 Posted : Monday, September 20, 2021 2:59:46 PM(UTC)
Was thanked: 202 time(s) in 140 post(s)
Draw a hole, select it and use the linear Duplicate Tool, fill out the right values or take it from the darawing and press ok. and you have your holegrid in 2D. Make the right frame around the grid and you can extrude this as a perforated plate. A alternative to this is the pattern function of Shark Pro.
Edited by user Monday, September 20, 2021 3:00:46 PM(UTC)  | Reason: Not specified
dep2352
#3 Posted : Wednesday, November 17, 2021 4:24:42 PM(UTC)
dep2352
How do I find and fix gaps in viaCAD v10?
dep2352
#4 Posted : Wednesday, November 17, 2021 4:28:15 PM(UTC)
dep2352
Why can't I extrude a draft angle from midpoint planes..
murray
#5 Posted : Thursday, November 18, 2021 5:51:21 AM(UTC)
murray
Gaps in profiles?
murray
#6 Posted : Thursday, November 18, 2021 6:00:49 AM(UTC)
murray
It's a confused scenario, extrude with draft from one side only and use linked mirror to provide the other.
thanks 2 users thanked murray for this useful post.
damhave on 11/18/2021(UTC), GARLIC on 11/18/2021(UTC)
Guest (5)
