dah59
#1 Posted : Sunday, September 12, 2021 11:37:04 AM(UTC)
dah59
Hello,
I purchased this software to draw kitchen cabinet elevations. Some cabinet runs are over 12 feet wide. It would be much easier to layout the cabinets if there was a to scale ruler on the vertical and horizontal grid I have set up.
Thank you, David H
thanks 1 user thanked dah59 for this useful post.
specktech on 10/17/2021(UTC)
#2 Posted : Sunday, September 12, 2021 11:46:14 PM(UTC)
You can make up a start file. So every new part started will load the scales.
Draw out the scale you need in a file
save as to desktop 'startup.dat' as the file name
Move the file to
C:\Program Files\Punch! Software\SharkCAD 12 (sharkcad 12 will show as whatever version you have installed)
now start up the software and it'll load that default file. I have one set up full of renamed layers and things, just makes it easier
thanks 4 users thanked UGMENTALCASE for this useful post.
dah59 on 9/13/2021(UTC), GARLIC on 9/13/2021(UTC), jlm on 9/15/2021(UTC), specktech on 10/17/2021(UTC)
dah59
#3 Posted : Monday, September 13, 2021 7:10:53 AM(UTC)
dah59
Thank you, I will give it a try. Hopefully this will make it possible to create drawings the same way as my old QuickCad software.
Guest (5)
