covehithe
#1 Posted : Saturday, August 14, 2021 1:53:17 AM(UTC)
covehithe
Our community group makes 3D models for Sand Casting.
W are starting to make name plates and the 3D model Fonts need to have draft to make it easier to remove from sand.
Simple Question !! Can you quickly and easily put a draft angle on a font. = we have seen it done with solid boxes and models but not fonts.
thanks
MaiFy
#2 Posted : Monday, August 16, 2021 3:10:32 AM(UTC)
MaiFy
Hi Covehithe
Yes, taper or draft works with some fonts.
Here is a short video of doing a name plate. 3D Name plate link
It's quick and unscripted so it has a few rough moves.
I'm using Viacad pro version 10.
Edited by user Monday, August 16, 2021 3:14:05 AM(UTC)  | Reason: Not specified
