motorsportjpn
#1 Posted : Tuesday, July 6, 2021 7:53:19 PM(UTC)
motorsportjpn
I'm running Big SUR (MAC) top spec I9 processor and 64Gb ram.
shark cad build 1572
I open mesh analysis in powerpack and it instantly crashes.
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00007ffee4efaff8
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [841]
Other issues
"remove collapsed facets" (the message stays on the screen causing you to exit the software)
"check overlaps" same issue as above
"convert mesh to quads" (Instantly crashes)
what is this piece of garbage software, mesh to nurb, where did this option go! less isnt more.
#2 Posted : Tuesday, July 6, 2021 11:40:42 PM(UTC)
I've noticed a lot of issues in windows and the power-pack mesh options. I'm getting a list together to put in the BETA section of this forum. Make sure you put this in there and then they can test and fix.
