Gallery
Some products modeled in shark and rendered in keyshot (#4878)
Was thanked: 17 time(s) in 6 post(s)
Hi all,
It's a long time I have used Shark (and concept unlimited) to do my designs.
I posted some pictures of products I designed. All of this products are marketed now.
Bye,
francois charron attached the following image(s):
(90kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
Salut, Beau travail! Bravo. Je participe ©galement sur le forum de Luxion sous le pseudo: Antoine Antoine
Thanks: 224 times Was thanked: 177 time(s) in 107 post(s)
Trs beau travail Franois ! ----French Connection----
Originally Posted by: francois charron Hi all, It's a long time I have used Shark (and concept unlimited) to do my designs. I posted some pictures of products I designed. All of this products are marketed now. Bye,
Just a question about your renderings, did you create all your text inside of Shark? Are they just decals? Or added in photoshop later?
Thanks.
I prefer to model texts in Shark when they are simples (drawn in Illustrator and imported to Shark - I can reuse the .ai file to make printed-screen after in production).
In the case of complex pictures (Like Abri Services or Jegou), I use a decal.
I never use Photoshop to correct or change an image after rendering (it's not my professional philosophy).
I would precise that these products are entirely designed in Shark - from concepts to the industrial production documents. For the Evolis and Aquaroll products the inner parts are designed in Pro_E and Solidworks. I never had a problem to exchange data between them.
I use Keyshot to have a very good quality and Artlantis for the productivity.
You can see some others products in my web site :
www.exadesign.com . I will add some others products pictures before Christmas if I have the time to take photos.
Francois
PS : sorry for my english. I post some new products for the pleasure.
(37kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
bravo, je suis trs impressionn© par ta production, forte qualitative et ©motionnelle. Antoine
Bonjour Franois, j'ai une question: utilise tu Shark pour tes mise en plans technique 2d? Je me bats depuis de nombreuses ann©es avec Shark, CU, ... afin d'obtenir des plans techniques de qualit©, mais rencontre toujours les mmes bug et incoh©rences dans ce type de travail. C'est quelquefois, rendre fou.... je n'exagre pas. Autant j'adore ce logiciel pour mes travaux de mod©lisation, autant je le d©teste pour le mode MTS, mise en plans. Je parle surtout des raffinements, lignes, polices, hachures etc, tellement difficiles mettre en oeuvre et sans compter les bug, disparition, incoh©rences etc. Je me suis mme demand© si je ne devrais pas changer de logiciel, juste pour cette partie de dessin 2d... Je suis trs curieux de ta r©ponse. Sinon, j'ai peu prs les mmes routines que toi, soit: mod©lisation avec SharkFX et rendus avec Keyshot que j'adore. Cordialement. Antoine
To translate Antoine's comment in a few words : "Tim, please, fix the bugs in MTS". ;)
hahahhahahahahahaha!!! Thanks JLM maybe for the 12 version....
Salut,
Je fais ma mise en plan sous shark pour les cotes simplement.
Tout le reste est fait dans Illustrator : police, couleurs, sp©cifications, cartouche, ajout d'images
Car effectivement shark bloque rapidement en souplesse.
Je joins le type de plans que je peux faire.
salut et bon week-end,
Franois
chassis tolerie.pdf
(1,737kb) downloaded 11 time(s). fonderie alu.pdf
(278kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Merci beaucoup Franois, Tim? entends tu? lis tu? Ecoute les pros...les vrais, ceux qui ont besoin de raffinements, enfin le minimum requis pour cr©er des plans dignes de ce nom :) Cordialement. Antoine
Antoine, if you write your comment in french, for sure Tim didn't read it!
Gallery
