Thanks: 17 times Was thanked: 3 time(s) in 2 post(s)
After making a new design it seems that some objects inside the design are displaying the gripper at an angle?!?!?!
Is there a way to undo this? I've got no idea why did has happened or how to correct this.
Edited by user Sunday, May 2, 2021 8:35:56 AM(UTC)
| Reason: Added attachment
WORP3 attached the following image(s):
(17kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 95 times Was thanked: 69 time(s) in 39 post(s)
Yes it is possible,
go to "Inspector window" set "user positioning" and "set origin" - see printcreen attached.
Magicart
magicart attached the following image(s):
(282kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: magicart Yes it is possible, go to "Inspector window" set "user positioning" and "set origin" - see printcreen attached. Magicart
The problem with this is that it's not permanent. If you switch back to center of object then the axis reset has been reset again :(
Originally Posted by: rokoko I know, did see that post but unfortunately I didn't find any permanent solution that seems to work. Beside of just learning to work with it :(
Also copying all the objects in a new empty file isn't working, it's probably some invisible object parameter.
Edited by user Wednesday, May 5, 2021 8:16:39 AM(UTC)
Not sure if ViaCAD pro has an animation menu. It has the command "set axis" to reset the axis of an object. I use SharkCAD Pro.
Originally Posted by: rockyroad_us Not sure if ViaCAD pro has an animation menu. It has the command "set axis" to reset the axis of an object. I use SharkCAD Pro.
Thanks for the input but VIACAD isn't having a animation menu, or at least not that I know of.
