WORP3
#1 Posted : Sunday, May 2, 2021 8:35:09 AM(UTC)
WORP3
Netherlands
After making a new design it seems that some objects inside the design are displaying the gripper at an angle?!?!?!
Is there a way to undo this? I've got no idea why did has happened or how to correct this.
Edited by user Sunday, May 2, 2021 8:35:56 AM(UTC)  | Reason: Added attachment
WORP3 attached the following image(s):
magicart
#2 Posted : Sunday, May 2, 2021 12:35:21 PM(UTC)
magicart
Poland
Yes it is possible,
go to "Inspector window" set "user positioning" and "set origin" - see printcreen attached.
Magicart
magicart attached the following image(s):
Zrzut ekranu 2021-05-2 o 21.00.16.png (282kb) downloaded 0 time(s).
WORP3
#3 Posted : Tuesday, May 4, 2021 8:54:06 AM(UTC)
WORP3
Netherlands
Originally Posted by: magicart Go to Quoted Post
Yes it is possible,
Magicart
The problem with this is that it's not permanent. If you switch back to center of object then the axis reset has been reset again :(
rokoko
#4 Posted : Tuesday, May 4, 2021 10:25:21 AM(UTC)
rokoko
there is a solution in shark. see topic
http://forums.punchcad.c....aspx?g=posts&t=4732
post #9
WORP3
#5 Posted : Wednesday, May 5, 2021 8:13:42 AM(UTC)
WORP3
Netherlands
post #9
I know, did see that post but unfortunately I didn't find any permanent solution that seems to work. Beside of just learning to work with it :(
Also copying all the objects in a new empty file isn't working, it's probably some invisible object parameter.
Edited by user Wednesday, May 5, 2021 8:16:39 AM(UTC)  | Reason: Not specified
rockyroad_us
#6 Posted : Wednesday, May 5, 2021 11:49:39 AM(UTC)
rockyroad_us
Not sure if ViaCAD pro has an animation menu. It has the command "set axis" to reset the axis of an object. I use SharkCAD Pro.
WORP3
#7 Posted : Thursday, May 6, 2021 9:26:06 AM(UTC)
WORP3
Netherlands
Thanks for the input but VIACAD isn't having a animation menu, or at least not that I know of.
