How can you change the company name that appears in the information box when you make a 3d to 2D drawing
machtool attached the following image(s):
(38kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 630 times Was thanked: 102 time(s) in 65 post(s)
You are in the MTS-View, click the company name to be changed, the Inspector window will pop up where you can edit this company name in question, et voila ! or you edit a template file according to your likings...consult the manual, it is well explained !
Originally Posted by: machtool How can you change the company name that appears in the information box when you make a 3d to 2D drawing
You have to add this information to the 3d model in properties first. After the sheet is created it will not update.
Go
File,
Properties
and then fill out the form. I can't remember which does which with the description etc.
