machtool
#1 Posted : Sunday, March 14, 2021 7:43:53 AM(UTC)
machtool
How can you change the company name that appears in the information box when you make a 3d to 2D drawing
machtool attached the following image(s):
Screenshot 2021-03-14 100341.jpg (38kb) downloaded 0 time(s).
GARLIC
#2 Posted : Monday, March 15, 2021 7:18:28 AM(UTC)
GARLIC
Was thanked: 102 time(s) in 65 post(s)
You are in the MTS-View, click the company name to be changed, the Inspector window will pop up where you can edit this company name in question, et voila ! or you edit a template file according to your likings...consult the manual, it is well explained !
#3 Posted : Monday, March 15, 2021 3:05:47 PM(UTC)
You have to add this information to the 3d model in properties first. After the sheet is created it will not update.
Go
File,
Properties
and then fill out the form. I can't remember which does which with the description etc.
