for lasercutting I do need connected polylines.
I do have ViaCAD 12, but I am not able to produce these lines...
Is there a way ?
For the moment a friend of mine is producing these polylines with TURBOCAD LTE.
There it is very easy:
Select "connect polylines","delete originals", "follow chain" ....
bidonville attached the following image(s):
(46kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Hello
I would use the tool Arc from Curve, and not use polylines at all. Arc are better handled by the laser, than polylines.
Edited by user Thursday, January 28, 2021 9:45:15 AM(UTC)
(54kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Does join curve applied to connected arcs or line segments and right-click "change object to.." polylines do it for you?
Edited by user Friday, January 29, 2021 3:22:59 PM(UTC)
Originally Posted by: murray Does join curve applied to connected arcs or line segments and right-click "change object to.." polylines do it for you?
Thanks for the idea, I tried this method, but the curves change their shape ...
Michael
(262kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jdi000 Hello I would use the tool Arc from Curve, and not use polylines at all. Arc are better handled by the laser, than polylines. Regards Jason
Hi Jason,
thanks for the hint.
I draw vectors over handsketches using "Interpolate Spline", than using "Arc from Curve", which is a very good method for lasercutting.
The factory wants to have connected lines (polylines) in an DXF-file. "Grouping" in ViaCAD does not produce connected lines.
AUTOCAD and TurboCAD LTE does this easyli.
It seems, that in ViaCAD is no way to connect the lines that way.
Best Regards
Michael
Edited by user Saturday, January 30, 2021 12:05:52 PM(UTC)
(137kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Do you have a sample file? Maybe someone can give you a hint after manipulation and post it to the forum.
Joining curves to polylunes in Turbocad explodes them to line segment approximations or arcs, they don't remain curves.
Originally Posted by: rockyroad_us Do you have a sample file? Maybe someone can give you a hint after manipulation and post it to the forum.
Hi
rockyroad _us and
murray ,
here I do have an example file, as I cannot upload VC2, it is in DWG ...; in addition the file produced with TurboCAD LTE
and an screenshot of the file ..
1) Original head drawn in ViaCad 12 2D, same exported to TurboCAD LTE (DXF), connected Polylines,
2) imported via DXF into ViaCad, you can see in "Object Properties", that all connected lines are named "Polylines"
3) Ungrouped object with "showing points" ... almost all circles ..
Best Regards from Germany
Edited by user Monday, February 1, 2021 11:16:30 AM(UTC)
Head_VIACAD.dwg
(19kb) downloaded 5 time(s). Head_LTE.dxf
(238kb) downloaded 9 time(s). bidonville attached the following image(s):
(241kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Looks to me like the group is just named polyline but the entities are still made from lines and circles. The software just names the group that way as the name implies. If you want to convert to splines, you will have to use the join command with a .0005" tolerance to have the profile as close as possible. So connecting two curves will be converted to spline. and if you want to have better control, after spline, you can convert further to Bezier. It tends to keep the curvature at a minimum deviation in this sequence. You can convert to poly lines but that will just convert to a line or lines despite being curved. Beats me why the software does that. I don't use polylines professionally, it is very elementary.
2 users thanked rockyroad_us for this useful post.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Hi bidonville,
I usually export as .dxf R12. Your file had 2 areas that had segments
that were visible in the cutting software that I use.
I traced the 2 arcs, and exported as a .dxf, should cut OK.
Head.dxf
(21kb) downloaded 1 time(s). L. Banasky attached the following image(s):
(54kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Hi Larry, thanks for jour help ! Best Regards ! Michael
