PowerPack
Problems with unrolling a surface
Thanks: 5 times Was thanked: 3 time(s) in 3 post(s)
I have tried many options to try and unroll a surface to produce a cutting outline for a brass sheet head light for a model steam locomotive, I am making.
I first made a solid model then converted it to a Surface. From the surface I tried using the PowerPack unroll command, but am have virtually no success. I did look at a tutorial on YouTube of Viacad unfold command and could reproduce similar results. Thus I think the PP unfold / unroll command is working, however not on the model I made.
I have attached a picture of the top of the loco head light I am trying to unfold. I ideally need a layout of a side and front. I have also attached a picture of the side of the light, which was converted from the solid model to a surface. I then manually removed sections from the front, back and other side mesh elements. Still I had no luck with unrolling it.
I have also attached a copy of the file I am working with. I am using TCMac Pro V 11 and V12 with the Powerpack.
Any help or guidance would be gratefully appreciated.
Thank you,
Keith
Top Headlight.tcp.zip
(1,481kb) downloaded 5 time(s). Keith2019 attached the following image(s):
(142kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 33 times Was thanked: 110 time(s) in 86 post(s)
Convert it to a mesh first. It doesn't work very well with surfaces at all. If it was a ruled surface you would have more luck with it as it has something to progressively unroll.
Attached file converted to a mesh and unrolled. Just select the surface, right click, change object type, select mesh
Top Headlight.sfx
(1,568kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
ViaCAD Pro 10, 11 + Power Pack Pro Shark CAD V12 + Power Pack Pro Windows 10 Pro- MSI GL72 6QC-32GB RAM
Thank you very much UGMENTALCASE, your guidance and help worked perfect :-) Also thank you for updating the Top Headlight file.
1 user thanked Keith2019 for this useful post.
PowerPack
