farmertom
#1 Posted : Wednesday, June 10, 2020 2:00:35 PM(UTC)
farmertom
Hello
I have recently switched to version 12 of ViaCAD 2d/3d.
Now I noticed that the push/pull function is no longer available.
In version 10 and 11 I had this function.
How can I activate this function again?
#2 Posted : Wednesday, June 10, 2020 2:10:13 PM(UTC)
Was thanked: 246 time(s) in 170 post(s)
https://www.punchcad.com/product-line-comparison
I'd contact support. I had this on V11. False advertising lead me to believe that the product had more features than it did. It says in this link that it's in your version. However there is every chance they have moved it out and not corrected the website
ViaCAD Pro 10, 11+ Power Pack Pro
Shark CAD Pro V12 + Power Pack Pro
Windows 10 Pro- MSI GL72 6QC-32GB RAM
murray
#3 Posted : Sunday, June 14, 2020 10:29:53 PM(UTC)
murray
Was thanked: 103 time(s) in 84 post(s)
They've taken ACIS out of 2D/3D. VC 2D/3D doesn't interop .igs, .stp and .sat anymore, no push/pull, no MTS, no blend or shell, no "advanced surface/solid modelling" - all ACIS. I started using PunchCAD at its first release, V5, in 2007 because the ACIS routines and interop made it great bang-for-buck and hugely useful as a complement to TurboCAD Pro. I bought it almost as an impulse buy and because of that, I was completely comfortable about the length of time it took me to learn to use it well (real men don't need instruction, so everything was suck it and see. Probably a year of dabbling...). I moved up to SharkFX at V7, because everything I'd done with VC is still usable. 2D/3D V12 is not an upgrade over earlier versions, and it's not a compelling first step in CAD anymore, either. The 3D printing utilities are useful, but not unique. If there was a decision between ACIS or D-C constraints, I think they made the wrong choice. The comparison page says it does Skin, Cover, Net, Extrude, Lathe, Sweep, and .dwg is the only export format remaining that can describe curved surfaces, so are these curved surfaces or meshes in .dwg?
Earlier 2D/3D also do .spl spline/polyline import by coordinate list and curve and surface by law, .dat grid nurbs surface by coordinate. Are they moved up to Pro only now too?
Edited by user Sunday, June 14, 2020 11:24:52 PM(UTC)  | Reason: Not specified
GARLIC on 6/15/2020(UTC)
DBM
#4 Posted : Wednesday, December 30, 2020 9:55:16 AM(UTC)
DBM
Murray, spent twenty minutes looking for the push/pull feature, then I found your post. Thank you. So, in your view, what is simplest workaround for someone who relied heavily on that function? Thank you.
#5 Posted : Wednesday, December 30, 2020 10:50:31 AM(UTC)
I think if you use deep select, pick the face you should be able to drag it using the gripper.
DBM on 12/30/2020(UTC)
