scloutier
#1 Posted : Tuesday, December 15, 2020 6:00:21 AM(UTC)
scloutier
I'm snapping tangents to connect two circles. Everything looks fine till I zoom in and the tangents are not actually touching the circles which leaves me with a gap.
I've tried changing the resolution but this does not work...
Thanks for any advise.
thanks 1 user thanked scloutier for this useful post.
specktech on 6/14/2021(UTC)
#2 Posted : Tuesday, December 15, 2020 6:21:12 AM(UTC)
Hello
Sounds like a visual,if you can use select chain on the line and and it grabs all the circles then they are sharing same point even though it's not visual on the screen. What display mode are you using?
scloutier
#3 Posted : Tuesday, December 15, 2020 6:50:58 AM(UTC)
scloutier
Thanks for the reply, I'm fairly new at this.
I selected one of the lines then used the select chain in the edit menu and nothing seemed to happen. I also tried select all with select chain and nothing. Still gaps when I zoom in or try and extrude.
I'm using the top view as this is in 2D.
#4 Posted : Thursday, December 17, 2020 1:13:16 PM(UTC)
Hello
Can you copy out an example and upload it here?
mitchb
#5 Posted : Thursday, December 17, 2020 7:37:35 PM(UTC)
mitchb
I'm not clear as to which tangent you are using. There is a logic cursor tangent and a constraint tangent. The constraint tangent doesn't need the line to touch the circle, it can be tangent with the circle but not necessarily tangent on the circle. In this case, use the extend tool to intersect the circle. If the line extends past the circle, use the trim tool.
To use the logic cursor select the line tool and move your cursor over the circle and look for the word "on" to popup, only the on should be seen. Click, hold, and drag away from the circle then pause, the word "tangent" should popup. Continue dragging to the second circle and follow the circle edge until "tangent" pops up again, release the mouse. Click and hold is the key for this to work. Another option here is to drag the mouse away from the circle at 90° and the word "perpendicular" will popup. This is will give you a line perpendicular to the circle.
thanks 1 user thanked mitchb for this useful post.
gebhardt
#6 Posted : Friday, December 18, 2020 5:53:44 AM(UTC)
gebhardt
Was thanked: 10 time(s) in 6 post(s)
If cursor show tangent on both end whilst drawing its is tangent. Might be ea resolution issue. Mark all questionable elements , go to "edit" menu > "change resolution" > set elements to "super fine" . also set "even distribution" for these elements.
thanks 1 user thanked gebhardt for this useful post.
posh.de
#7 Posted : Friday, December 18, 2020 8:46:24 AM(UTC)
posh.de
the visualization on the display (with it's limited resolution) does in general not represent the true geometric model, i.e. will show gaps etc. if zooming far enough in. Therefore geometry and their construction points and geometric relationships shouldn't be evluated by trying to zoom in to extreme zoom scales but by using the snapping and coordinates shown by the 'Inspector' only.
thanks 1 user thanked posh.de for this useful post.
rockyroad_us
#8 Posted : Friday, December 18, 2020 8:58:43 AM(UTC)
rockyroad_us
It sounds like a graphics card issue. if you trim at the tangent locations, it will smooth out.
thanks 1 user thanked rockyroad_us for this useful post.
MaiFy
#9 Posted : Monday, December 21, 2020 10:46:17 PM(UTC)
MaiFy
Hi there
My 2 cents worth.
Some times I use the corner trim tool or (trim 2 entities tool at corners tool)
That rejoins the lines seamlessly.
If it doesn't rejoin it often means I have gone out of 2D mode and slipped into 3D mode and it wont trim because I am in a different plane.
The lines might look all good to trim but the lines are not even close. ((Try holding down AlT with your left hand, hold down right click and drag mouse at the same time,)) Press "D" to return to normal, (anyway thats how my shortcuts work.)
With the circles I use the break tool on the inside of the object, generally in 2 places near where I want to trim, the reason for that is that the circle lines have directional memories and the trim at corners tool can delete parts of the circle that you want.
It you break it in 2 places it generally stops this.
Little vid explaining what I mean
thanks 3 users thanked MaiFy for this useful post.
L. Banasky on 12/22/2020(UTC), specktech on 6/14/2021(UTC), GARLIC on 6/15/2021(UTC)
specktech
#10 Posted : Monday, June 14, 2021 9:41:37 PM(UTC)
specktech
This is exactly the same problem I am having. I am doing the tangent process exactly like it should be done and getting gaps. Trying everything possible to get this dialed in. Gonna watch your vid MaiFy.
Thank you so much for making this little video. This is the exact same thing that I was struggling with. Watched it about 5 times. Think I got the fix in my head now. Just need to try it out. Thank you so much Maify. Going to watch all the other vids you have on Vimeo. Peace out.
In reading your explanation a few times over, You have really steered me in the right direction. Thank you 100 times Maify. I would have never figured this out with out your help. Going to get this dialed now. Big smiles Maify.
Wanted to thank all the other posts on this subject on this page. I read every word a few times over. And I think I am slowly getting my head wrapped around this. Thanks ViaCAD and Shark users.
Edited by user Monday, June 14, 2021 10:21:16 PM(UTC)  | Reason: Maify made me edit it 3 times. Thanks
thanks 1 user thanked specktech for this useful post.
MaiFy on 6/22/2021(UTC)
#11 Posted : Thursday, June 17, 2021 4:42:09 AM(UTC)
Was thanked: 255 time(s) in 168 post(s)
I am not able to recreate this issue. I get no real gaps when it snapping the right way. Maybe use the trim tool to remove the unneeded parts of the circles.
Edited by user Thursday, June 17, 2021 4:48:50 AM(UTC)  | Reason: Not specified
specktech on 7/19/2021(UTC)
Guest (5)
