Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
I tried to rotate box text and most of the text disappears. I tried a different approach by rotating the work plane, and then inserting the box text and it disappears again. Has anyone else seen this problem or know how to work around it?
Edited by user Sunday, November 15, 2020 7:10:04 PM(UTC)
ViaCad 10 Pro ViaCad 9 Windows 10
Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: creativecad I tried to rotate box text and most of the text disappears. I tried a different approach by rotating the work plane, and then inserting the box text and it disappears again. Has anyone else seen this problem or know how to work around it?
Can you try another font ?
Some can be rotated (Arial)...
So far, no success. Are you using the gripper, or the rotate tool? Arial did not work.
Originally Posted by: creativecad So far, no success. Are you using the gripper, or the rotate tool? Arial did not work.
Both gripper and rotate tool are working fine for me (Sharkcad Pro 10 & 12 - Mac ) with fonts like arial, Helvetica, Skia....
