hello,
Youpie!:p
great tool.
Please, see the atached files.
Thanks Tim and Co.
Antoine
(169kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Antoine,
Yes the bend tool is very good, there are many possibilities.
I have been playing and was building intersecting surfaces inspired by Rinus Roelofs. After the surface was created I simply bent the surface around a circle.
I have attached the first of a few I will be attempting to build in Shark (I only have the demo of shark, so cannot post the model.)
- Steve
(33kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Steve.M Hi Antoine, Yes the bend tool is very good, there are many possibilities. I have been playing and was building intersecting surfaces inspired by Rinus Roelofs. After the surface was created I simply bent the surface around a circle. I have attached the first of a few I will be attempting to build in Shark (I only have the demo of shark, so cannot post the model.) - Steve
Interesting!
that's amazing Steve ! It looks like a close up from the science bit in a Pantene ad
yes, I have some interesting surfaces to attempt,... just for fun.
There are a number of examples of what i am playing with here:-
http://www.rinusroelofs.nl/pr-c-holes/pr-c-holes-00.html I am seeing if I can set up Shark to render the surfaces.
- Steve
the rapidrender presets in Shark aren't bad for a quick render
Hi jol, Currently I am just trying out light domes to see how shark reacts to an attempt to create GI I will try out the presets a little later. - Steve
