a.wieneke
#1 Posted : Tuesday, October 27, 2020 11:21:07 AM(UTC)
a.wieneke
Hello,
i like to draw a ring with text around.
The problem is, to find the right size for the text.
I cannot see how the text looks, when i use 'along curve text'
I want the text horizontel to the ring, see picture.not vertikal, what is a little easier to use.
So, first i need to change objekt type, to see what Text along curve did.
After this i have to do all the steps again.
And it is very difficult and/or not possible to change the textsize.
Is there any hint or a walkaround ?
Thank you very much for every help!
Sorry, i forgot; i tried it with ViaCad 10 pro and with SharkCad 12
Edited by user Tuesday, October 27, 2020 11:52:04 AM(UTC)  | Reason: Not specified
a.wieneke attached the following image(s):
Bildschirmfoto 2020-10-27 um 18.00.07.png (111kb) downloaded 1 time(s).
viele Grüße
Andreas
http://www.wieneke.biz
SharkCad pro 14
OS X 14.0
GARLIC
#2 Posted : Tuesday, October 27, 2020 12:10:40 PM(UTC)
GARLIC
Was thanked: 103 time(s) in 65 post(s)
Hi Andeas: in this particular case I can recommend to make use of MoI3d + flow command, it is very easy, search the forum, there are very many examples of this specific task which might help you in your special workflow.
regards
G.
rockyroad_us
#3 Posted : Wednesday, October 28, 2020 9:20:09 AM(UTC)
rockyroad_us
You can try to use the curve bend tool for solids. Keep in mind that you will need to do trial and error figuring out the alignment orientation but you can accomplish that by drawing a bounding box around the text so you can pick orientation and the two points required. Hope that helps.
thanks 1 user thanked rockyroad_us for this useful post.
GARLIC on 10/28/2020(UTC)
a.wieneke
#4 Posted : Wednesday, October 28, 2020 11:58:38 AM(UTC)
a.wieneke
hello Garlic,
the version of MoI3d is not working with MacOsx, they wrote, i have to wait for Version 4
hello rockyroad_us
the ring on the picture is made with the bend tool. But it streches the letters to much.
Maybe i have to make every letter by hand an move i to the place i want, not very comfortable.
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
rockyroad_us
#5 Posted : Wednesday, October 28, 2020 12:10:28 PM(UTC)
rockyroad_us
You might need to figure out the outside perimeter of the ring and draw a line corresponding to the perimeter so that you can position the letters along the line. I don't know how the back of the letters behave. Maybe you can post a file to help.
a.wieneke
#6 Posted : Wednesday, October 28, 2020 12:19:23 PM(UTC)
a.wieneke
here it is:
sorry, i forgot , in this file/version, i made already "change objecttype", with the letters, so you can see the them
Edited by user Wednesday, October 28, 2020 12:24:04 PM(UTC)  | Reason: Not specified
testtext.srk.zip (616kb) downloaded 4 time(s).
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
rockyroad_us
#7 Posted : Wednesday, October 28, 2020 12:58:03 PM(UTC)
rockyroad_us
Here's my attempt. Note that I added a bounding box corresponding to the perimeter of the ring. So when you pick your 2 poins in the curve bend it will correspond to the perimeter. Note that I spaced the letters the way you would want to space them. There's a line I drew which I got from your text spacing to set it off from the end of the box so it will be spaced from the first word since it will bend.
The key is that if I bend the bounding box, you will get that ring which you have extruded. You can suppress the bend feature to see how I arranged the letters in the bounding box.
testtextV2.sfx (994kb) downloaded 6 time(s).
a.wieneke on 10/29/2020(UTC)
murray
#8 Posted : Wednesday, October 28, 2020 10:47:23 PM(UTC)
murray
Does your version of SharkCAD 12 or VCP 11 have wrap? It's under solid utilities in SharkCAD Pro, it wraps your text around a solid cylinder, I think that'd make it really easy to visualise spacing and style, it's associative so you can jigger the spacing and everything else. I've used wrap here with your text. To produce the text, I put a solid block under the text curves and extruded the text from it as a single protrusion feature. The text is completely associative and editable, and the height and draft of the protruded letters is editable in concept explorer. I bent the block with text at the face that the text's extruded from around the diameter of the ring, and intersected it with a thickened cylindrical sweep to produce the letters.
Edited by user Wednesday, October 28, 2020 11:11:25 PM(UTC)  | Reason: Not specified
testtextvisualise.sfx (1,616kb) downloaded 2 time(s).
ring letters and wrap.PNG (193kb) downloaded 2 time(s).
thanks 2 users thanked murray for this useful post.
GARLIC on 10/29/2020(UTC), a.wieneke on 10/29/2020(UTC)
Keith2019
#9 Posted : Thursday, October 29, 2020 5:25:42 AM(UTC)
Keith2019
Hello Andreas,
I found a YouTube video called "Punch!Cad v12 Tutorials - Wrap (Imprint, Emboss, Engrave). It is very good and informative. Maybe it can help you.
I will try to copy the link here: [url=https://www.youtube.com/watch?v=5GAk5UzVscs]. https://www.youtube.com/watch?v=5GAk5UzVscs
Regards,
Keith
thanks 1 user thanked Keith2019 for this useful post.
a.wieneke
#10 Posted : Thursday, October 29, 2020 5:39:28 AM(UTC)
a.wieneke
Thank you rockyroad_us,
I have the impression that some letters are mirrored.8see picture)
but i will play araound with this solution
Thank you murry,
yes sharkCad has wrap. I will try this and think it is my solution.
Yes, thank you Keith2019
for the youTube link.
i have seen this, monthe ago and forgot it, shame on me :-)
Bildschirmfoto 2020-10-29 um 12.32.16.png (192kb) downloaded 1 time(s).
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
Guest (5)
