ctkjose
#1 Posted : Friday, October 16, 2020 9:01:46 PM(UTC)
ctkjose
Im starting to convert many of my drawings into symbols mainly 3D printing stuff (bearings, nema motors, T alum extrusions, etc) and will be posting my symbols in a GitHub repository.
If any body is interested I will post more info once I get the report up.
On a side note (Im a newbie so pardon ) while using symbols I found that (V12 Pro on Mac 10.15.5):
1. The tooltip that shows the name is very inconsistent, meaning that most of the times it won't be displayed.
It happens when you move the mouse on top the tooltip is displayed, you move the mouse you loose it you move the mouse outside the symbol them hove back to it and you won't get it. In a similar fashion you get it on one symbol but when you hover on the next you don't get it.
Most of the times you get it once and don't get it agin until you scroll, change tabs, or change from one symbol folder to another.
2. Is there any way to search or make favorities? (besides moving your common used ones to your "Symbol" folder)
