Afternoon all.
I have a set of curves which are best fitted from some scanned data. I'm trying to create a revolve using them all. I've attached the file with them in. 6 Sections and a centre line. I've had some absolutely crazy results which clearly aren't right, and others which fail either with a warning of "this feature is not yet implemented" or some other illegal act which I didn't understand
Any help would be great.
Cheers
TCT00108.sfx
(24kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
UGMENTALCASE-
played with your set of curves for a while and got nowhere. "Skin" would yield a surface for the N curves but would not close the surface gap between the first and last curve...... picking the N curves with a different starting curve yielded slightly different surfaces with the gap in different places..... the shortest curve always induced a twist unless it was at the beginning or end of the sequence of curves submitted to "Skin". best of luck with your challenge
be well
Art
artesmith@earthlink.net
1 user thanked Art Smith for this useful post.
Hi thanks for giving it a blast for me. I'm the same. I can use more sections, but I'm sure I've done stuff like this before. Just can't figure it!
Thanks: 184 times Was thanked: 159 time(s) in 109 post(s)
Played around with it, probably not what you are looking for.
Just a WAG.
(72kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
So what have you done there Larry? I'm actually getting it to work but it will need 4 more section to get the rounded shape better. I'm actually getting different results now I've saved turned off and opened it up again!
I just drew a line to close each objects endpoints, and did a 'REVOLVE' solid, using the line in the middle. I almost never work with surfaces, so I really don't know what I'm doing. Larry
Ah ok got you. Yeah just make them closed profiles. Ok cool cheers :-)
They can be done as surfaces with Shark's tools, two-point revolved surface worked for me, shift-selecting the profiles, releasing and nominating the axis' end points. Verify count says 6 arcs and 15 lines for the profiles, 21 surfaces are the result. But I passed a cut section through the surfaces afterwards and they're really incoherent, there's not an obvious closed profile for a solid, no evident design intent.
(22kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked murray for this useful post.
Originally Posted by: UGMENTALCASE Afternoon all. I have a set of curves which are best fitted from some scanned data. I'm trying to create a revolve using them all. I've attached the file with them in. 6 Sections and a centre line. I've had some absolutely crazy results which clearly aren't right, and others which fail either with a warning of "this feature is not yet implemented" or some other illegal act which I didn't understand Any help would be great. Cheers
Enjoy!
TCT00108_3_fillettwolines-rad0,2mm.sfx
(27kb) downloaded 2 time(s). TCT00108_4_edit-changeobjecttype-bezier.sfx
(29kb) downloaded 1 time(s). TCT00108_5_jojncurve.sfx
(89kb) downloaded 1 time(s). TCT00108_6_interpolatespline.sfx
(91kb) downloaded 1 time(s). TCT00108_7_guideskinsurface.sfx
(132kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked luk72 for this useful post.
Result. Enjoy!
luk72 attached the following image(s):
(148kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
