a.wieneke
#1 Posted : Thursday, May 28, 2020 2:03:12 PM(UTC)
a.wieneke
Hello,
if i make a rotateobjekt with meshlathe and want to scale it,
with uniform scale, everything works fine,
when i uncheck uniform scale, nothing happens!?
what do i think wrong
Edited by user Thursday, May 28, 2020 2:05:33 PM(UTC)  | Reason: Not specified
a.wieneke attached the following image(s):
Bildschirmfoto 2020-05-28 um 21.57.47.png (217kb) downloaded 0 time(s).
Bildschirmfoto 2020-05-28 um 21.57.15.png (212kb) downloaded 0 time(s).
viele Grüße
Andreas
http://www.wieneke.biz
SharkCad pro 14
OS X 14.0
digitalphaser
#2 Posted : Friday, May 29, 2020 8:00:39 AM(UTC)
digitalphaser
Edit --> Remove Links
Claus
#3 Posted : Saturday, May 30, 2020 3:05:11 AM(UTC)
Claus
Denmark
Originally Posted by: a.wieneke Go to Quoted Post
Hello,
I had problems with surfaces not updating when editing profiles. The problem was fixed in a new build. You should contact tech support and request an update.
Claus
a.wieneke
#4 Posted : Tuesday, June 2, 2020 8:44:14 AM(UTC)
a.wieneke
Thank you
i was not looking for a work_around.
I was just wondering, and thougt, other users are wondering also :-)
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
a.wieneke
#5 Posted : Tuesday, June 2, 2020 8:53:00 AM(UTC)
a.wieneke
Hello,
Claus
THank you,
i just upgradet from ViaCad pro 11
to sharkcad 12 , built 1544.
the thing is, in ViaCad 11, it works fine.
viele Grüße
Andreas
SharkCad pro 14
OS X 14.0
