#1 Posted : Wednesday, May 27, 2020 12:25:05 AM(UTC)
Was thanked: 105 time(s) in 81 post(s)
Morning.
So after you have done an instance using the linear duplicate, how do you edit it?
Currently just deleting it and doing it again but seems a bit daft when it records that it's an instance and everything to do with an instance but you can change it?
Using v12 sharkpro, probably applies to all other versions
Cheers
Edited by user Wednesday, May 27, 2020 12:26:32 AM(UTC)  | Reason: Not specified
Shark CAD + Power Pack Pro
L. Banasky
#2 Posted : Wednesday, May 27, 2020 7:05:11 AM(UTC)
L. Banasky
Was thanked: 86 time(s) in 69 post(s)
Right Click and 'Explode Instance'
Edit in 'Concept Explorer'
Don't know about a 'Linear Duplicate'
Edited by user Wednesday, May 27, 2020 7:23:44 AM(UTC)  | Reason: Not specified
Explode Instance.jpg (56kb) downloaded 0 time(s).
Exploded Instance Edited.jpg (47kb) downloaded 0 time(s).
#3 Posted : Wednesday, May 27, 2020 7:30:39 AM(UTC)
Yeah that is an option with linear duplicate the explode thing.
When you do a polar duplicate you can click each individual part and adjust it's angle in the inspector. Thought it may have been similar?
