Thanks: 16 times Was thanked: 8 time(s) in 7 post(s)
Hello, i noticed, since some days ViaCad Pro 12 is available. I think about upgrading to from 11pro to 12pro or to shark 12. But my last experience was the upgrade to 11. I upgraded but i still use Version 10 pro with power pack pro, because with Version 11 i have everyday some crashes, with the same object i use in 10, without crashes. So, can someone tell me, 12 is more stabil now ? or maybe shark is more stabil ? And, i wonder, why i alway have to reimport my settings for my technical sheets and my weight for my materials. This should be able to keep it with an update. Hope you have good news, so i will buy this update.
Thanks: 631 times Was thanked: 103 time(s) in 65 post(s)
Hi Andreas, I think the best bet would be to get hold of a full working Trial (14 days) and check within your usual workflow, just my 2cts ! Regards G:
Thanks: 15 times Was thanked: 31 time(s) in 27 post(s)
I upgraded from 10 to 12. I skipped v11, it was very bad. So far no problems vith v12. Punchcad removed the free trial, you may want to contact them and ask for it. I got it before it was removed but upgraded shortly after. I agree that settings should be stored so they stay when a new build is installed. I suggested this to the developer years ago and he agreed. However nothing has changed there so far.
Thank you, so i will ask for an trialversion stay healthy!
Could you please report back here about your total experience, this kind of feedback could help us all, thanks ! G.
Was thanked: 13 time(s) in 5 post(s)
To claus : You seem to say that Vcp 12 works without bug ! which operating system is installed on your pc ?
Originally Posted by: axel To claus : You seem to say that Vcp 12 works without bug ! which operating system is installed on your pc ?
Those are big words, on my mac I have not had problems so far. I’m sure there are bugs to be discovered and fixed. I’m using SharkCad pro on the latest MacOS.
SharkCAD Pro v12 first look... warning! "concept explorer", "render library" and "select mask" windows are useless, they cannot be manipulated or resized. I have pointed to similar problems since the version of ViaCAD Pro v9 but ... now it is worse
Originally Posted by: Claus Originally Posted by: axel To claus : You seem to say that Vcp 12 works without bug ! which operating system is installed on your pc ?
Bug update, I have seen several times now and reported that push/pull of faces stop working on certain models. I'll post here if this issue get fixed.
Update: development comfirms it's fixed in next build.
Edited by user Wednesday, April 29, 2020 8:20:06 AM(UTC)
| Reason: Update
Can I ask whether that build will be released? F all got fixed on V11, and still hasn't and won't be.
Originally Posted by: GARLIC Could you please report back here about your total experience, this kind of feedback could help us all, thanks ! G.
now i have the trial of shark and the trial of ViaCad 12
In Shark it is sometimes difficult to change the tools. For example if i used the mesh to analytic, the curser still stays with this tool.
It is not possible to change directly to the selection tool. First i have to select something else f.e.: splinetool, etc..
And ViaCad pro i will test the next days, but the trial is without Powerpack
so i hope Shark will become better, because this is with Powerpack.
I think, they should make the upgrade sheaper, when you come from ViaCad 11.
i bougt it and not realy used ViaCad 11. Most of the last month i used ViaCad 10, it was on my Mac more stabil.
1 user thanked a.wieneke for this useful post.
@Andreas: may be you would like to check if SharkCAD Pro 12 (your trial version no ?)
has these important bugs already been fixed as reported many times:
http://forum.punchcad.co...ts&m=37613#post37613 posted by jlm,
especially MTS (Model 2 Sheet) has always been quite an annoying topic,
wondering about your findings, many thanks in advance !
regards
G.
1 user thanked GARLIC for this useful post.
Originally Posted by: a.wieneke Originally Posted by: GARLIC Could you please report back here about your total experience, this kind of feedback could help us all, thanks ! G.
How did you get your
free trial ? When I tried with this address, I get error
404 !!! very frustrating !!!
This is the link in question:
https://www.punchcad.com/free-trials Thanks for your attention to this topic,
regards
G.
You need to contact Punchcad for the trial.
I don't find value in going from vc pro 11 3d to vc pro 12 3d. I stopped at v11. I mean, if the upgrade was more on par with $150 for a full v12 pro 3d (all features), then I might do that, but as-is, the pricing for upgrade + additional features, seems like an unwise choice.
Edited by user Monday, June 29, 2020 12:23:36 PM(UTC)
