perry
#1 Posted : Tuesday, April 14, 2020 1:55:16 PM(UTC)
perry
Was thanked: 8 time(s) in 5 post(s)
I have a model I'm working on that has three interconnected parts, stacked one on top of another. I'd like to make an exploded view with some space in between them, and some reference lines connecting the objects through the bolt holes I've inserted.
Is this possible in ViaCad Pro v11?
I'm thinking something like this: https://openbuilds.com/media/traming-concept.854/
thanks!
axel
#2 Posted : Tuesday, April 14, 2020 2:31:20 PM(UTC)
axel
Was thanked: 12 time(s) in 5 post(s)
Yes, it is possible: an example below with the components of a wheel
MEZELIO 08.jpg (1,750kb) downloaded 25 time(s).
thanks 1 user thanked axel for this useful post.
jlm on 4/24/2020(UTC)
perry
#3 Posted : Tuesday, April 14, 2020 2:38:37 PM(UTC)
perry
Thanks. How is that done? I'm not finding a way to do that anywhere
#4 Posted : Tuesday, April 14, 2020 2:43:00 PM(UTC)
It has to be done manually move each piece and create any lines as needed. I would create a new file and import each piece or copy and paste.
Edited by user Tuesday, April 14, 2020 2:43:37 PM(UTC)  | Reason: Not specified
perry
#5 Posted : Tuesday, April 14, 2020 2:48:05 PM(UTC)
perry
Ahh. I was hoping there might be a way to do it automatically. Thanks.
murray
#6 Posted : Wednesday, April 15, 2020 5:48:57 AM(UTC)
murray
It can be semi-automated by drawing a line the separation distance between the components, selecting all except one and moving the selection from line start to finish, referring the intellicursor to the line's start and finish, drop the next component, move the remaining selection from start to finish, drop the next component, move the remaining etc. Vector/assembly lines drawn through the axes of the mating holes/fasteners can be dashed in inspector pen properties, thickened if you want with the pixel weight setting, unit weight settings don't vary onscreen visuals. Do it with a copy of your work and unlinked parts, it'll probably screw up dependencies if you use linked originals and could refuse to regen.
perry on 4/15/2020(UTC)
