Hello,
I work with Viacad 9 pro.
If I create 2 primitives and select both, I can rotate them with the gripper tool as often as I want.
But if I first group them and rotate them afterwards, after 2 rotations in different axes, ghost outlines of the primitives appear: A circle with a sphere or a triangle with a cone.
Only grouped primitives with roundings are affected: Sphere, ,cone, cylinder and torus.
Block, prism and pyramid are not affected.
Surprisingly elipsoid is also not affected.
Stefan
starmbi attached the following image(s):
(30kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
