Tips and Tutorials
custom colors for Mac users...only, h© h© (#2128)
Hello,
Here is a tips to assign a custom color with exact reference to an entity.
For Mac users only h© h© h© h© ...
PC go home!!!
oups:p
see the attach files please.
Cordialy.
Antoine
(85kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Antoine, Thanks for the Tip ! JL
Two tips.
You can change all of the colors in the color window by creating a file similar to the zipped text file at the bottom of this post.
You can also change the size and shape of each color cell by editing the [PenColor] values in the SFXPrefs.ini file contained in (mac) library/preferences/Punch!/Shark FX. In the screenshot I have my cells set at 15 X 20 pixels so that the overall size of the window matches the size of the object info window and I can actually see the colors.
rgb.txt.zip
(3kb) downloaded 5 time(s). NickB attached the following image(s):
(22kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Shark FX 9 build 1143
OS X 9.5
matter.cc
>>I have my cells set at 15 X 20 pixels so that the overall size of the window >>matches the size of the object info window and I can actually see the >>colors. Nick, I forgot all about that feature! Thanks for bringing it up. Tim
Originally Posted by: NickB Two tips. You can change all of the colors in the color window by creating a file similar to the zipped text file at the bottom of this post. You can also change the size and shape of each color cell by editing the [PenColor] values in the SFXPrefs.ini file contained in (mac) library/preferences/Punch!/Shark FX. In the screenshot I have my cells set at 15 X 20 pixels so that the overall size of the window matches the size of the object info window and I can actually see the colors.
Thanks, Nick good one!
Tips and Tutorials
