Plasron
#1 Posted : Tuesday, February 25, 2020 7:22:03 AM(UTC)
Plasron
Hello new to the forum
May I ask if Viacad can edit broken lines, if so are there any videos showing how to connect broken lines
Thanks in advance
Ron
Edited by user Tuesday, February 25, 2020 7:22:41 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, February 25, 2020 7:39:32 AM(UTC)
Thanks in advance
Ron
Hello Ron
Can you be more specific on what broken lines you are referring to? Are you talking 2d profiles? profiles with gaps ?
Plasron
#3 Posted : Tuesday, February 25, 2020 7:51:50 AM(UTC)
Plasron
Thanks in advance
Ron
Hello Ron
Thanks Jason
2d DXF file with broken lines, I use to use Inkscape to connect the broken lines
Ron
Edited by user Tuesday, February 25, 2020 7:57:16 AM(UTC)  | Reason: Missing info
Plasron
#4 Posted : Tuesday, February 25, 2020 8:20:31 AM(UTC)
Plasron
We are doing CNC Plasma cutting, using Inkscape, Sheetcam, Mach3 and Now Punch Viacad 2D
I used Inkscape to connect overlapping and broken lines (lines that were not joined together).
I’m liking what I see with Punch ViaCAD, hope with time I will better understand it, hope it has a dxf editor.
Ron
cad'n'stuff
#5 Posted : Wednesday, February 26, 2020 4:48:28 PM(UTC)
cad'n'stuff
Was thanked: 41 time(s) in 21 post(s)
You basically have 2 options:
1: Connect curve - Does exactly what it says. Select 2 curves and it connect the 2 curves.
2: repair curve - Select as multiple curves and it looks and repairs any gaps between them
cad'n'stuff attached the following image(s):
#6 Posted : Friday, February 28, 2020 11:47:20 AM(UTC)
Ron
Viacad 2d can modify your 2d profiles for cutting. Lots of tools depending on situation
1. First thing is to open profile and right click and use the select chain tool - that can show the gaps in the profile.
2. Trim and extend tools
3. Repair profile tool
4. connect curves
5. The arc from curve tool located in the arcs tool bar is great from getting the profile to arcs vs a chopped up polyline with a million line segments.
If you can post an example file we can walk thru these options.
