magelland
#1 Posted : Friday, February 28, 2020 3:21:03 AM(UTC)
magelland
Hello
We are currently using Viacad Pro v10.0.4, Build 1359, French version
We regularly use STP files from manufacturer websites, and sometimes we get the ACIS error "Missing integer in restore file".
This happens when using drag and drop directly in Viacad
If using File/Import : file does not open, but no error displayed
For instance see attached file that works perfectly : 1401G
I cannot upload a file that generates an error, sends me a "length error" when uploading : here is the link :
https://www.schaffner.co...ered-power-entry-module/
There are 6 files in the ZIP, all generate the error
Is there a size issue ?
I noted that file that works is 486kB, vs 6.65MB for the one that does not
Thanks in advance for your help
Alain
1401G.stp (487kb) downloaded 2 time(s).
GARLIC
#2 Posted : Friday, February 28, 2020 3:59:38 AM(UTC)
GARLIC
Was thanked: 103 time(s) in 65 post(s)
we checked your files (the schaffner-link) in my company and all could be imported
without any probs with shark11/rhino6/spaceclaim/moi3d/solid edge.................
thanks 1 user thanked GARLIC for this useful post.
magelland on 3/1/2020(UTC)
Elektroniker
#3 Posted : Friday, February 28, 2020 11:38:14 AM(UTC)
Elektroniker
I imported one of these stp-files out of the zip-file with ViaCad Pro 11 and had no problems too.
Elektroniker attached the following image(s):
thanks 1 user thanked Elektroniker for this useful post.
magelland
#4 Posted : Sunday, March 1, 2020 12:47:28 PM(UTC)
magelland
Hello
Thank you to Garlic and Elektroniker
As I wrote in my message, most of the time, I can open stp (or other format) without issue.
It is only time to time, for unknown reason that this does not work.
Alain
magelland
#5 Posted : Monday, March 2, 2020 8:41:53 AM(UTC)
magelland
Hello
A few more information :
I tried today on another PC, 2nd licence same Viacad version / same build : same issues
My configuration if it can help :
HP Zbook, Intel i7, 16GB RAM, SSD 1TB, Windows 10 French
Graphic card : NVIDIA Quadro P2000
Alain
#6 Posted : Monday, March 2, 2020 8:57:20 AM(UTC)
It also imports very well in Shark V12 beta.
Perfect parts. No error.
magelland
#7 Posted : Monday, March 2, 2020 9:09:07 AM(UTC)
magelland
Just had another idea : I tried our former ViaCad version (V9.0.8 Build 1180), and it worked......
File was opened correctly....
