Import/Export
Can't import jpg or pdf files
In earlier versions of VCP I could import jpg or pdf files and scale them to get approximate measurements for parts or furniture. In the new version they come in as an opaque blue box. Any ideas? Jim
Originally Posted by: giametti In earlier versions of VCP I could import jpg or pdf files and scale them to get approximate measurements for parts or furniture. In the new version they come in as an opaque blue box. Any ideas? Jim
Hello Jim
What version are you using? Mac or PC?
Hmm. I just tried to import a jpg into VCP10 which used to work. Same result. I'm thinking its another screwup with MacOS Catalina. Worst decision I ever made.
Edited by user Tuesday, January 21, 2020 8:33:35 PM(UTC)
I'm running ViaCAD Pro 11 on a Mac, running Mac OS 15.1 (Catalina).
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
I confirm with Shark pro on Mac : I get an opaque blue box.
Even with the pictures that were imported before, correctly with V11 ---> they are blue-boxed when I re-open the files now.
Please,
can you explain me what a Opac Blue Box is ? (Foto)
I have "only" the problem that I can't use the Arrange-Menu; if I put the picture to the background it is not visible (workbench not transparent) and I can't set in front anymore.
So I have to draw into the picture, overlaying the lines or hide /unhide the picture using layers.
horst.w
GER
Pic 1 = imported picture not selected
Pic 2 = my scetch
Pic 3 = picture selected, seems like underlay
Edited by user Wednesday, January 22, 2020 2:18:12 PM(UTC)
(80kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: horst.w Please, can you explain me what a Opac Blue Box is ?
The complète image is displayed as a blue patch, with nothing in it.
It seems to be a Mac issue.
JL
Edited by user Thursday, January 23, 2020 3:56:40 AM(UTC)
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
With Windows 10, I can import the jpeg fine, but the pdf locked up the the Shark build 1508 program. Sam
ViaCad 10 Pro ViaCad 9 Windows 10
I tried a different pdf file and it worked with Windows.
Import/Export
