Thanks: 1 times Was thanked: 10 time(s) in 6 post(s)
In adding fillets and chamfers is is very useful to have a part in transparency view shading. Can we have a function to toggle quickly between transparency and non-transparency? Or is it available anyhow? Have not found it yet. Best regards , Lutz
Thanks: 221 times Was thanked: 171 time(s) in 103 post(s)
Originally Posted by: gebhardt In adding fillets and chamfers is is very useful to have a part in transparency view shading. Can we have a function to toggle quickly between transparency and non-transparency? Or is it available anyhow? Have not found it yet. Best regards , Lutz
Hello Lutz,
Object property---> Display---> Transparency
(449kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Yes, this is what we use permanently. But this does not work quick enough for me. I use Pick Objekt > right click > transparency or Pick Object > Inspector > Display > Apply I have now set a shortcut to toggle very quick between gouraud shading and wire frame shading. Works now for me, but applies to all objects, which ist a bit confusing while have a lot of detailed parts in wire frame.
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
There is a couple of options at the bottom of the main tool pallet to change to wireframe or dimmed hidden lines.
ViaCad 10 Pro ViaCad 9 Windows 10
Can you bang it on a keyboard shortcut? I have a few set up with my space mouse. It has a few buttons on it which I have programmed (shortcuts) to regularly used things
I thought I posted a response but it disappeared. Anyway, yes you can go to the Render commands in the Shortcuts. There are options there to assign a key to toggle between wireframe and a shading type.
I have set a lot of short cuts to f.e. show hide functions and various standard views. This makes me very fast in view manipulation. Now i have set an additional short cut to toggle quickly between my standard render mode "Gouraud with edges" and "wireframe". What i would love ist to have a quicker possibility to add or remove transparency on a specific parts. Nice to have...
