hello,
possible?, add this parameter in the render window?
DPI: 72, 150, 300, etc
See the attach file please.
Thanks.
Antoine
(35kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
>>>DPI: 72, 150, 300, etc Hi Antoine, I've had quite a few requests to add a DPI setting. However, the width and height are currently displayed as pixels. What do you think if we went with a width/height in inches/mm and a DPI setting? Suggestions and feedback would be very welcome from all. Regards Tim
Width + Height + DPI would work well for me
Concur w/JOL and Antoine, would be very useful.
Brian Graham Mac OS Ventura 13.6.3 Mac mini Apple M1 16GB 1TB SSD Shark FXv 14 Build 1641
I prefer to have both the height/width DPI option and the pure pixel resolution setting. Similar to photoshop, the 2 setting types auto update when the other is modified. Gary
Thanks: 26 times Was thanked: 6 time(s) in 3 post(s)
No, no, dont take away the pixel dimensions! It is logical for a rendering and/ or screen capture to refer to the number of pixels. Pixel based photos are in pixel values. Fo the same reason digital cameras operate with pixel values, photo databases do the same and so on. If you do want to relate to dimensions in mm or inches and link with a dpi value open the file in a photo editing program and adjust as you like. Dont confuse the fact that the optimal resolution you need for different use of a photo basically means the effective final visible size will be media dependent for the same original. If you want to use a render for print you will be better off converting to cmyk and adjusting to the proper dpi setting later on anyhow as I guess renders still will be rgb.. I dont mind there beeing a pull down menu though, but do not take away the pixel values, that would just not make any sence!
hello Tim,
after rendering, I will give Photoshop for my image, a resolution of 300 dpi for printing and archiving printer.
see the attach file please.
also exemple with C4D
If SharkFX can make a rendering already configured DPI, it would be more practical and faster.
Cordialy.
Antoine
(23kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Gary Similar to photoshop, the 2 setting types auto update when the other is modified.
I agree with Gary. This approach works well, as users can alter whatever metric they want, and see the effect to the rest of the measurements instantaneously.
D
